MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
I'll be installing a Hydratech hydraulic brake booster kit over the next few days, and reporting on the progress in this thread.
The package from Hydratech is due in tomorrow, so I figured I'd get started with the disassembly.
As everyone says, the very first step is to inspect the whole power steering and braking system, since everything needs to be in good shape.
First step was removing the seat. Technically, this is not necessary. Technically, you could decide to fill your brake lines with water. Technically, a lot of things are possible. Some are less recommended than others. Don't even attempt this with the seat in place. I know, from working on the wiring under the dash, just how difficult working around the seat can be. Excrutiatingly painful would be another way of saying it (and I don't use Novacaine at the dentist, or even think that getting my teeth drilled is more than "uncomfortable," so if I say that something is painful, I really mean it).
Removing the seat is a piece of cake. Four bolts. Slide the seat back, flip up the carpet at each corner, and remove the front two bolts. Slide the seat forward, same deal for the rear two bolts. Fold it forward, and pull it out. If you can't handle that part of the job, stop right now and have a professional do the rest of the install - you don't want to be working on a brake system...
Next step is the steering column. Again, this is not technically required. But it will make your life so much easier. Insert the key to unlock the column, centering the wheels, then remove the key and tap the wheel slightly to one side to trigger the lock. That will keep the internal parts aligned correctly. Disconnect the battery. If you're smart, you'll use this chance to install a switch on the battery hot lead (Ecklers sells them, as do many other vendors - just get one designed for side-terminal batteries). The switch makes life so much easier, especially when you're trying to align the bolt with the terminal, and you leave the switch in the "off" position so you don't have to deal with arcing.
The column is fairly simple. There's a panel on the underside of the dash, below where the column goes through. It's held on by a few screws (probably varies by year). Remove it, being careful of the headlight vacuum over-ride switch. Locate the spot where the column goes through the firewall, and the two bolts that mount the plate (one to either side). Remove te nuts from those bolts.
Now, pop the hood and look at the firewall, where the column comes through. You should see a plate on the firewall, that was connected to the nuts you just removed. One of the bolts is welded to the plate - the other is loose. Remove the loose bolt, then pull the plate away from the column. Mine had some wires attached, so I just swung it down and out of the way, hanging on the wires.
Next, locate the steering box and rag joint. Just behind the rag joint is where the column attaches. There is a clamp with a 12-point bolt (just in case anyone is unaware, 12-point bolts don't require any special tool - just a ratchet and an ordinary 12-point socket). Now, because you aligned the wheels straight forward, there's a good chance this won't be pointing straight up. Mine was pointing toward the fender (that might always be the case, or it might vary by year - I don't want to make any promises). You can ratchet it off with a little bit of time and effort, or do it nice and quick with an air ratchet, if you have one.
With the column disconnected from the steering, it's time to slide under the dash again. This is the last bit. If you haven't already done so (and your car has this part - some may not), remove the A/C duct. Gentle but firm pressure to the side should allw you to pull the inboard end down and away from the rest of the ductwork, then you can pivot it down and rotate it aft to remove it from the vent (this will make sense if you get under there and look).
After the duct is out of the way (or if you didn't have it to begin with), remove the two bolts that hold the column to the dash. They should be pretty obvious. The column will drop a few inches, but it doesn't weigh much. With it down a bit, you should be able to disconnect the wiring. There should be a long, narrow connector on one side, a connector on the dimmer switch, two on the ignition switch, and one small one (I think it's for cruise control, so your car might not have it)(this one is easy to miss, to be careful). With the two connectors on the ignition switch, chances are that one has to be removed before the other (the one closer to the firewall had to come off first, on mine).
Verify that all wiring is disconnected, watch you don't snag any new wires or vacuum lines, and begin to pull the column toward you (if you have tilt, it may make things eaiser to adjust it so the column is straight, before you start moving it). There is a rubber boot that helps seal the column to the firewall, and you may need to coax it a bit to separate it from the column. You also need to be aware of the orientation of the mounting plate, with respect to the brake pedal shaft and the various wires. This is where having the tilt centered is helpful - it's much easier to rotate the whole assembly when it is straight instead of bent.
With a little bit of care, you should have spent about and hour, and have the seat and column sitting on the floor of your garage (or someplace safe).
Be careful not to move the steering components on the car, or you'll have to re-adjust everything to get the wheel straight. This is why I recommended straightening the wheel at the start, rather than rotating it for easier access to the 12-point: if you have to re-adjust, it will be easier to measure from the frame to the brake disk on each side, and adjust to have them equal, than it would be to get the wheels and column aligned by trial-and-error.
More on the actual install, tomorrow...
Joe
Joe
