I broke my horn
minifridge1138
USA
1982 Black Fastback
Hey everyone,
I took my steering wheel off and put it back together.
But now my horn does not work.
Can someone tell me what I did wrong?
Thanks!
When you put your wheel back on you should have a spring that is wrapped around a contact rod. The rod sits in a pocket just below the contact ring. The contact ring has an extension arm that sits just above the rod. If all of this is assembled correct, with wire connected, hopefully you will have horn. Another thing to trouble shoot is to see if the horn is working when the telescope is collapsed. I had a horn that would only work when the telescope was collapsed. If I extended the column the horn would not work. Best of luck.
Ok, I got the horn to work.
30 minutes with the AIM and your advice solved the problem.
Thanks everyone!
