6
69vettester
Finally got some time to devote to finding and fixing my nightmare vacuum failure that snuck up on me this fall.
I went to the store and got 25' of vacuum hoses in 3 sizes, then started bypassing and rerouting everything in every combination I could think of, hoping the headlamp doors would suddenly close. No results. I used a rubber hose to listen for a hiss at every T and junction.Nada...
I was really scratching my head, and just happened to be feeling
around the relay thats mounted between the headlamps. All the way on the bottom of that relay shaft is the "total leak" . its so bad that it didnt even hiss coming out. I see now that its what happens when the relays diaphram totally fails( the air just pours out the bottom of the shaft).
Got the relay ordered from Zips today. And earlier, Roy Truelsen had pointed out that I had the wrong hoses so I got the complete color coded hose kit, and the reserve check valve that didnt work either.
I "should"have my headlamps working correctly again around the first of the year..halleluyja..
Then I can move on to the next thing..my fix list seems to get bigger instead of smaller??:L
Ill post the results when I get it done..
Thanks for the help and motivation
TC
TC
