M
Michael 427
I posted a reply to my thread I guess dumb under 1967 brakes, I guess fighting this problem for over 18 months stupid things will be done. The problem the car darts to the right when applying brakes, installed all new brake lines and hoses had calipers redone didin't solve the problem, then I purchased all new calipers new castings from Delco never been a car and pads and bleed the system with pressue one of the new items and fit to master cylinder and the problem still is still there, front right caliper works fine left front skips when applying a lot of pressure the right one locks up. No the car does not have a portioning value no J56 brakes any ideas would be appreciated, I don't want the big block to sit all year but no choice, I guess I will drive the chevelle. People at work say the calipers must float on the rotor no sure what this means, how can you determine if the calipers float, only other item I have not tried are wheel bearings both both wheels spin freely and no grinding noise, I also mic the rotors and both are the same. Help.
Michael 427
Michael 427
