norvalwilhelm
But I use them. I believe it ties the block and heads together better then bolts. It is a pain individually installing the 16 studs, putting thread sealer on the block end and then a blind nut of the end and gently screwing it all the way into the block but not tightening it.
Sliding the gasket over is difficult in that is has to be perfectly square or it will hang up.
You then have to slide the head over the studs and that can be another problem with sufficient room on the drivers side. But after the head is on 16 washers followed by 16 nuts and then the torquing in 20 pound increments in a spiral pattern. It too me about 2 hours to install one head and I took the easy on first
This is just a shot of one of the intake ports, While the camera doesn’t do it justice they are big
Bolts would be so much easier. :lol:
