R
ReggieD
I reviewed the schematic and wiring diagram. I am wondering if this idea will work. The vette has 4 speakers.
Each speaker has its own amp. The amps are powered thru a power relay. Each amp takes a pre-amp input.
Purchase a nice sounding AM/FM CD Player with RCA outputs (same as pre-amp output). Connect the RCA inputs into a passive equalizer that has a four channel output. Make sure the equalizer output levels are pre-amp levels. Let the equalizer drive the four factory ampified speakers. Connect the amps power relay to the antenna power output lead that comes from the radio. That same lead should also power the equalizer.
THe radio opening on the dash is pretty big. The opening should be able to accomodate a CD player and an equalizer.
Can this idea work or is there something special about trying to use the ampified speaker with an aftermarket radio?
I need input from the radio specialist on this forum;worship
