I have been troubleshooting the original carb on Gail lately. She starts late (after second or third crank), the choke does not engage to get her to 2,200 rpm, and when she idles, she stumbles and dies off after idling for a while (almost as if she is not getting enough fuel in the reservoirs of the carb).
With the dwell connected, she is metering for a little while, and then the dwell needle goes dead and below 10 degrees. Shortly after this, she dies off. If I accelerate the engine, she goes back to metering with the computer and mixture solenoid to a neighborhood of 25 degrees.
She flashes only code 21 from the CCC. I am not sure how long this code has been there, but the procedure is pretty straight forward to correct the throttle positioning sensor, so I don't feel that it is a problem.
But when I follow chart 1, page 6E1-17 of shop manual for dwell is fixed below 10 degrees, and if I cover the throttle body with my hand, she goes back to metering. So obviously, I began looking for an air leak. I tightened the carburetor lid screws a bit, checked some of the connections, and I find nothing. So I went ahead and removed the carburetor, and while I looked around, I found that the primary wells' protruding portion on the side of the throttle body that are normally covered with plastic/rubber (I don't even know what they are called) and their associated shields are lose and cracked. See pictures
The phillips screw driver tip is pointing to it...
a close up of it without the plastic/rubber shield
The shield for the passenger's side on the carburetor is cracked and comes off easily as well.
So my question is, does it matter if they are missing the plastic/rubber shield?
