I haven't been able to pass for the past two years.
The state requires a standard of .80 while I'm reading a 1.9 measured in GPM on hydrocarbons.
Standard of 15. on carbon monoxide while I'm reading a 26, measured in GPM.
What is going on here? Why are they reading so high?
In the past two years, I have replaced:
all 3 cats
EGR
PCV
plugs
wires
distributor cap
distributor rotor
charcoal canister
Only things I can think of are getting the injectors cleaned and the air pump. I hope it's not the injectors because taking the plenum and all that other stuff off to get to the injectors will be a PITA.
I need suggestions. Should I check the plugs again? They're 2 year old Bosch +4's. What plugs do you suggest?
This is getting very frustrating.
ad
all 3 cats
EGR
PCV
plugs
wires
distributor cap
distributor rotor
charcoal canister
![martini :m :m](/data/assets/smilies/martini5.gif)
