S
scuby22
Hi, I'm in need of some help. One thing that I am researching is the stamping in the VIN location. The car has a "CE" number stamp on the pad. Everything I research about "CE" blocks indicates that there is no way to document where the engine came from. The only recommendations that I have been given are to check the casting number and make sure it's a 3970010 block. Then make sure the casting date code is correct. The car was assembled in January of 1971. The block was cast in December of 1970. It sure looks like it could be an authentic dealer replacement. The nice thing is that the car was originally sold at the local dealership. All the titles indicate that the car has never left a 100 mile radius. I have contacted all but one of the original owners and no one has ever done any engine work to the car. All the numbers (excluding the block) match. I have checked the following:
Heads, intake, carb, alternator, water pump, TI (still has orig coil with sticker on it.), 6500 Tach, trans. (vin matches), rear end, single fuel return.
Any advice would be great. I have the second owner sending me original pictures of when he purchased the car. Pretty cool
Thank you
Thank you
