H.H. McCool
- Joined
- Sep 18, 2004
- Messages
- 6
- Location
- tennessee
- Corvette
- 1994 polo green, LT1 coupe, 6-speed trans
Help! I recently had a tune-up (new wires and plugs) done at my local chevy dealer. Although things seemded ok at first, I soon discovered that if I stepped on the gas at low revs, the engine lost power and really hesitated. In first gear, or if the revs were up, there was no problem, although I felt that there was a general loss of power. The engine also made a funny, indescribable noise, not real loud, during the hesitation. Since I had already had a problem with this formerly reliable dealer, I decided to find another mechanic. The next morning, I drove the car as normal with the exception that the really long intrance ramp to the freeway that I use was deserted and I really gunned it through the gears all the way up, running right to 5000rpm, but no higher, in each gear. I then parked the car for a couple of hours. When I got in and started to drive it again, the engine was making a loud knocking noise. I drove it home, put it on a transport and sent it to a mechanic that a friend in the business recommended.
He has not broken it down, but he says the problem is "deep" in the engine and he's guessing that it is a broken piston!!??!! Does this sound reasonable? Does anyone have any ideas, suggestions, or comments? I am devastated! It's going to cost a fortune to fix it if he is right. He even suggested that I think about replacing the engine and suggested maybe a Jasper re-manufactured job.!!??!! I am sending the wrecker tomorrow morning to pick it up and take it to the dealer just to get a second opinion, but, man, I would appreciate any counsel that you guys have to offer. Thanks -HHM-
