black_81_vette
Hello gang!! I just finished putting a 3.54 gear set in my 81 wich had a 2.72 set. Im also running a 4 speed trans,after reading all the posts I could find here im still a bit confused on how still to fix the problem of my speedometer reading about 20 miles an hour too fast.I am aware that the gear on the output shaft is19t and the one on the cable is a 38t. what I need to know is there is a few of you guys that have 81s that have done this swap what combo of gears in the trans did you use? Did you get a bigger gear for the cable end gear or did you have to swap out the whole deal? help!!!!!!:confused
