- Thread starter
- #21
Paranoid
I replaced the carb gasket, and ran a new vacuum line to the canister. I pushed the distributor further back CCW. Can't go any more because the tach cable is hitting the firewall. I had to try to start it now to take advantage of my spotter who came home from school but has to go back soon for a football game.
It started right up( I have the idle screw set to high), no back fire, no misses, no shaking or bucking. It ran for about 6-7 min (could have been longer) @2500rpm's like a champ, I had my wire tying down the throttle and got out of the car to walk around to check for leaks & such. No smoking either, must have burned everything off this morning.
I pushed the distributor CW but the engine liked it better where I had it originally.
No coolant leaks, but the fans never turned on at 165?? Oil pressure 40-50, temp reached 200.
Then after about 7 min it started getting a miss! Still ran but the rpm's dropped to 1500. I tried to give it more gas but that made the rpm's even worse.
Then fuel started leaking out of the fuel pump!
Right along the seam where the rubber membrane is. :crazy:
Maybe it's me, but I can barely hear those solid lifters---I have the "special oiler" ones from Isky, with a 0.024 hole in the bottom center. Supposed to help lubricate the cam better.
I shut it down. Looks like I'll be working on the fans and the fuel pump.![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
Why the onset of a miss after running so strong??
![Eek! :eek: :eek:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
