Wajulia
I just rebuilt an E4mE (1981 CCC carb). Put it on the car, started right up, choke engaged , fast idle perfect, kicked off when it warmed up then stumbled and died, increased the idle speed, 1100 out of gear, 900 in gear and it idles pretty good (a small skip every 5 seconds). Took it out on the road, great throttle response, great transition from primary to secondary, drives great.
Bring the rpm down to under 1000 and it stumbles and stalls.
Checked all the vaccuum ports, all look good (the carb I replaced it with ran great at idle). Seemed to be idling a little rich ( eyes stinging meter) so I turned the idle screws in to about 2 turns out for each, same issue
No check engine light
Any thoughts as to what to look at next?
