N
nyernga
Once upon a time in a galaxy far far away I changed my IAC, in line fuel filter, adjusted the TPS per the service manual and cleaned the TB. Lo and behold the gremlin is still there. Start car and a heavy fuel smell appears, car runs fine but at no specific temp while sitting at a light, the engine begins to "hunt" going from a 500 rpm to 1200 then back to 400 then up to 1200 then if I don't "throttle" the pedal it stalls out. It eventually idles fine again.
No "service engine" light but I did pull 3 codes....a 13 which is an open condition on the O2 sensor. A code 34, MAF sensor, and a code 44 O2 sensor lean (which belies the fuel smell). Since they apparently are intermittent and are simply stored in memory and not triggering the service light I am kind of at a loss on which of the 3 to check. I'll probably just change out the O2 sensor for starters but I am open (unlike my sensor) to any and all ideas.......
Len
Len
