Idle Problem............HELP
ringleader
los angeles, ca USA
1990 Black coupe
Car won't hold idle and dies at starting and takes hitting the gas and finally it will even out. A new idle air control valve has been installed and it still does'nt work. My mechanic installed a new EMC to see if that was the problem, it was not. NO codes come up when he tests the idle. Everytime he sets the idle and then starts the car again another setting number shows up each time he does it. Has anybody experienced this problem and solved it or have any ideas what's causing this problem? The next thing he is going to try is testing the wirlng from the EMC to the idle air control valve. :Twist
Two questions: Once you get it started, how does it run from that point on. Also, do you have this problem starting cold, warm, or both? You also mentioned codes were appearing. Do you know what codes?
