B
BUDROW2
HI GUYS , I REALLY NEED SOME HELP HERE ,I HAVE TRIED PLENTY OF NEW A EXPENSIVE PARTS AND STILL HAVE NOT SOLVED THE PROBLEM FIRST OFF TRIED A COMPLETE TUNE UP ,,NEW CAP ,WIRES .ROTOR ,PLUGS,NEW INJECTORS ,A NEW DISTRIBUTOR, IAC,HAVE CLEANED THE IAC THEN REPLACED IT ,REMOVED TB AND CLEANED ,CHECKED FOR WATER LEAK IN TB OR UNDER IT FROM THE WATER COOLING LINES ,HAVE DONE A SMOKE TEST ON ENGINE WHEN COLD AND WHEN HOT,HAVE REPLACED ECM AND ADDED A NEW PROM FOR PERFORMANCE (ITS A PIGGIE BACK PROM) IM AT WHITS END WITH THIS ONE ,I SURE COULD USE SOME MORE HELP AND THANK YOU IN ADVANCE
BUDROW2
BUDROW2
