S
steve1ph
im having a problem with the idle on my `90. i put on the super ram all three pieces, 58mm tb, 36# injectors. now the car will idle around 800 then jumps to 15 hundred and stays there after about a few minutes. the idle is not erratic or hunting. just a nice lumpy idle and then it jumps. i wonder which sensor is telling the computer to idle up. at least thats what i think. what do yall think? i replaced the 02 and the map sensor. i had posted a few days about it jumping to 3 thousand. that was false. after checking the timing today my tack is about 13k off according to the snap on timing light we were using. we set it on 12 deg pos. good or bad?
