R
robert64
hello: On a 64 327/365 w/o power steering, what is the purpose of the extra belt and idler pulley that is mounted where the p/s pump would normally mount ? Curious !
Thank you
Thank you
robert64 said:hello: On a 64 327/365 w/o power steering, what is the purpose of the extra belt and idler pulley that is mounted where the p/s pump would normally mount ? Curious !
Thank you
it is factory item in case you throw of the long belt racing. the bearing used is a SBC waper pump bearing with one end of the shaft cut off.vette-dude said:What else does the belt turn? I think it goes around the WP pulley, crank pulley and the idler pulley. If that is so, it is the only way to take the slack out of the belt. I suspect the pulley arrangement is not stock or something has been removed that required the idler pulley arrangement be installed. Maybe you could post a pic.
Randy
motorman said:it is factory item in case you throw of the long belt racing. the bearing used is a SBC waper pump bearing with one end of the shaft cut off.
