BlackNBlue95
Well My trans went again, I just rebuilt it 6K miles ago and now it's doing some strange stuff... Such as I'm on the Highway going about 60 somthing and it's seems to be shifting back and forth between 4th and 3rd I think and then it started doing the same thing at low speed like it couldn't hold a gear. then it was also slipping in first the last time I drove it I had it set in manual first and was going about 18mph at 4grand (momentarily) I do hear some noise coming from the front of the trans and I suspect it to be the pump. Last time i had torn it down I did not rebuild the pump(it only had 40K miles on it). That time it had burned up the 3-4 clutch pack. so I replaced all the firction and steels and seals and gaskets and installed a shift kit. That rebuild was sucessful with the exception of a hard shift from park to drive when cold. other then that it was golden. So now I'm wondering what I should look for i don't see anything visually wrong in the pump. I plan of rebuilding the pump with a 13 vane rotor setup and replacing the all the friction and steels. in addition this time I will be also replacing all the electronics as well. Anyhow any suggestions on a converter I installed a TCI saturday night special last time and I'm not too impressed i was thinking like a 2000 stall speed who's converter should I buy and what stall do you guys recommend? also I heard the vigilante covnerters were the way to go. But arn't they like 700 or 900$?
Thanks much..
-Rick
Thanks much..
-Rick
