...with manual transmission, where did you take off the oil pressure line on the engine to run to the gauge?
I can't answer your question but you're welcome to spin wrenches with me in my garage anytime. Nice project!67HEAVEN said:...with manual transmission, where did you take off the oil pressure line on the engine to run to the gauge?
Bullshark,Bullshark said:I used the same location that my 454 had. The 502 block was cast and drilled for a port in the same place. The only challenge was that I had to drill a hole in the bracket that holds the clutch pivot ball so I could pipe the fitting out far enought to clear the bracket.
Bullshark
TWINRAY,TWINRAY said:I can't answer your question but you're welcome to spin wrenches with me in my garage anytime. Nice project!
67HEAVEN said:Bullshark,
Did you use a Scoggin's-Dickey bracket? That's what I have.
