T
Tbird
Can someone tell me can if you can put the original chrome ignition shielding on a replacement motor (NOM)?
Allthough I dont have an answer for youTbird said:Can someone tell me can if you can put the original chrome ignition shielding on a replacement motor (NOM)?
JohnZ said:Yes - all the attaching points for all the shielding parts are present on every SB block, assuming you're using stock-type exhaust manifolds.![]()
61 Silver said:What type of engine? There are tapped bolt holes in the block and brackets that bolt to the rear holes on the intake. I sure with a little creativity it could be adapted.
Ray
IH2LOSE said:Allthough I dont have an answer for you
Welcome to the forum.
Is it a small block or a big block,
I dont think its the block that makes a differance but I think its more of the excaust manifolds
