stevolwevol
The ignition switch in my 77 Vette will not turn back to accessory. I am under the impression that all 77 Corvettes came with an accessory position. Any way to fix this with out replacing the switch??
Not sure if it's the same or not, but on my 81 you have to push the key in before turning it back.The ignition switch in my 77 Vette will not turn back to accessory. I am under the impression that all 77 Corvettes came with an accessory position. Any way to fix this with out replacing the switch??
Ok I believe we do have the same setup.I tried this, but it didn't go. Either this switch doesn't have that option, or something is wrong with the switch. I don't know about your 81, but 77 has a lever.
Sounds like the switch could need adjusting.
this site has a good guide on how to do it Jim Shea?s Steering Papers
