corvetjerryd
I had a "little" accident in my 73 with a drainage culvert and really messed up my rear suspension...Broke the diff.cover,bent spring,mangeled right t-arm,bent shock..etc.:cry ...So now I have the money and I'm thinking about an upgrade to the rear suspension...I am looking at the VBP combo with the dual mount comp. rear spring and the smart strut setup(42000R)....I usually only use the car for crusing and "ocasoinally" barking the tires between gears...Have any you guys used this setup???? Is it overkill for me??? Would I be better off just using a 340# comp. spring and adjustable struts??? Just what is the advantage to "dual" mounts and smart struts???
I don't want it to ride to stiff or sit to high either.... I will call vette brakes and ask them too, but I was wondering if any of you guys had any 1st hand experience????
I know thats A lot of questions ....but you guys are GOOD.. .... Any info. you can give me will be of great help.....
