S
studiog
Here is my latest quandary. I have my car primed with high build primer surfacer and blocked to the point where I am very happy with the straightness of all the panels, most of the primer is down to where I can almost see through it. All my edges are nice and I'm happy with the fit of my trunk, deck lid, hood and my doors seem good too. I have inspected every nook and cranny. I have the whole car blocked to 320 grit. I need one more primer coat before paint but I want something that will lay down smooth with no texture so I don't have to go back to 220 grit paper and block again. Should I be thinking about just a sealer primer? Would an epoxy sealer be good at this point or should I still be using something with a little build? I know I don't need the corrosion protection and that the epoxy is hard to sand if I goof and it has a limited window for topcoating. I have decided to go with single stage urethane for my topcoat. Your comments are appreciated.
