8
87blackroxi
So I haven't driven the vette for 4 days now and jump in it this morning and It won't start. completely dead no volts.
I get home tonight and try to jump it after it charges up to about 12.8 volts and it doesn't even turn over. It makes some wierd clicking sound. Like
machine gun fire. very rapid.
So I check the fuses, all good. I remove the battery cables and clean the cables and terminal, there was very little corrosion. I look over everything and it looks normal. So I get it back up to 12.8 volts and when I turn the key the same thing happens, machine gun fire. No turning over at all. It sounds like a clicking sound very rapid. I'm stumped!
I had my lady come out so she could start the car and so I could hover over the engine to try to figure where the noise is coming from. At first it sounds like from the starter. then it sounds like the bottom of the distributor. Now I'm lost.
I replaced the starter about 6 months ago so it's practically new, went with A/C delco replacement. Also about 10 months ago I replaced the plug wires, distributor cap, and rotor. I still have the stock coil. One thing that didn't get replaced was the little thing that is about a half inch long, maybe 1/4 around and is held in by a spring. I can't remember what it's called but it's inside the distributor. when i replaced the cap and rotor, the new one that came with it broke I am now remembering I used the old one and never followed up to get a new one. I have no idea if it's relevant but I just want to try to give as much info as possible.
Then after disconnecting the jumper cables the car was dead again.
I need major help on this one guys and gals!!!!
