Injector/Manifold Question
Dougs91
Olalla Wash.
1991 blue coupe
Hey guys, I'm just about through changing my injectors on my 91.Car has 135,000 so,why not...(got the 22lb ford pink tops) anyway,got to injector 4 and have noticed on the intake manifold that about 1/4 of the "lip" that the o-ring seats behind is gone!!. Is this a problem? Hasn't been in the past. Old injector never leaked from there so do you'all think this is ok? Thanks-Doug
The most important item is this: the o-ring HAS to seal to the intake manifold. If the o-ring does not seal 100% around the injector, you will end up with a vacuum leak and your engine will not run right. As long as the o-ring has some material to make a tight fit all the way around, you will be good to go! :D
Save The Wave! :w
