- Thread starter
- #21
WhalePirot
So, where were you......
when I was struggling?
Seriously, thanks for the input.
I was not consistent with the direction of the bolts, as I prefer the Allen heads 'disappearing' from the outside to the nuts showing, but some holes would not allow that. It was nice to be able to tighten the bolts (or nuts) from inside the plenum. Final torque was applied to every nut.
Alignment of the plenum and runners holes was an issue (again). I had to 'encourage' some bolts into the holes (thanks, aluminum) instead of drilling enlarged holes which might allow unmetered air into the system. I sealed all plenum bolt holes; each bolt sitting in a small bath of Permatex black.
You'll find that tightening the hidden bolts offer many opportunities to bleed.
eddevil
