red70vette
The nuts on the bottom of the bezel are not very easy to reach. You have to remove the 2 access covers on the sides of the console. You then reach in and loosen the nuts with your fingertips. You may be able to remove the bezel with the console in. I have usually removed the console after the nuts are loosened. Lift the rear of the console and back it out making sure the nuts clear the bracket in the front.
It helps to have small hands which I don't.
