Installl booster / power brake in a 69, 427
TOR
Oslo, Norway
1969 Cab. 427 aut. Red
Hi
I need some advise before i install power brake ( booster ) in my 1969 427 cab.
I have a new booster width a push rod on, followed width a casket, (a little rod ? what is that for) and 2 brake lines and a new master sylinder. Do I have to make 4 new holes in the firewall ? -and make the hole from the old master sylinder bigger ? ( the 4 new holes do not fit very god with the bracket on the other side of the firewall and for one it is just fiberglass)
Shall I put the booster in the same position as the old sylinder , - or can I lower it ? Shall I use the existing clevis to conect the new push rod from the booster to the brake pedal ?;help​
Hei Vidar
om du har innstallert booster på din 69 mod. så ring meg 90 79 79 00
tor
