Intake manifold gasket...
tred95
PA
1995 Torch Red Hardtop 'vert
If this subject has already been discussed, bear with me.
I have started to replace my intake manifold gasket. The manual goes into a very detailed description of removing the manifold and everything connected or bolted to it.
It looks like the whole thing will come off with the fuel rails and the injectors still in place. Is this right?
Anyone done this?
Thanks,
Pete
Mine came off w/ hardware installed, it was then dissasembled on the "bench", cleaned up and resealed...
Hope this helps.
Thanks for the reply...I'll give it a try. It sure would make the job a lot simpler.
Pete
