- Thread starter
- #21
8
89ZZ4
Bill C
You need to find out what type of roller rockers they are. (ie self aligning or not) If not then you will need guide plates and hardened push rods. The TPIS ZZ9 cams are all designed around the 1.5 ratio rockers (Per TPIS). This cam with your stock springs could get a little iffy on the exhaust side using 1.5 ratios. Using 1.6 ratios bumps the gross lift up way beyond the springs ability.
If the rockers you can score cheap are narrow body self aligned it might be a good deal. You can get either ratio - self aligning - GM Performance Parts for 3/8 stud through Scoggins Dickey for about $280. They are made by Crane.
89ZZ4
89ZZ4
