F
Fred Hammerle
Can someone pls advise the correct intake bolt torque spec for a '64 327/365 with OEM aluminum intake manifold. Thanks, Fred
I agree with John. You might want to use the torque wrench on a few that you can easily access. This will help you recalibrate your elbow for the ones you have to use the box wrench onJohn Mcgraw said:Fred,
As others have said, the listed torque spec is 30 ft/lbs, but I don't believe that I have ever seen anyone use a torque wrench on these bolts! LOL
There are several that can only be accessed with a crows-foot adapter, and then you have to do the math to convert the torque to the proper value for the crows-foot.
I always just use the old calibrated elbow technique with a box-end wrench. LOL
Regards, John McGraw
