Interior Blinker Dummy Lights Don't Light
jeffn
East Aurora, N.Y.
79' Black Coupe
The right and left interior dummy lights do not light when the blinkers are turned on, or when the hazards are on.The blinker lever does not cancel automatically , but that's a different issue in itself.All of the exterior lights work as they should.Any ideas on how to fix this?
Thank you kind sir !...I've read and learned much from your posts.I'm just starting to get my '79 back into shape after it sat for a good 10 years.Only 41,700 miles on it, but a lot of little things to fix from non-use.Slow but sure will make it fast for sure..well....not that fast.It's a '79.
Well...The Bible says....A) Burned out bulbs. B)High resistance to ground at bulb socket. or C) Open grounds in wiring harness from front turn signal bulb socket to indicator lights......Looks like surgery is in order.
