ironwilbur
New member
1985 c4.If I totally remove the delay module what else will be effected?
If you are removing it because it is faulty ,you can connect the two white wires from pins A and D together and have the interior lights on with the doors open ,lights out as soon as you close the door.If I totally remove the delay module what else will be effected?
