klinderborg
Hello everyone. I have a weird one here. 2004 Z06 - box stock - 71,000 miles. Some times when making a left turn my check engine light turns on with a P0343 H code. I know it's the Cmp sensor code. The fact that there is an "H" after the code tells me it is something momentary. It doesn't happen on every left turn and sometimes it happens when I'm pointed in a straight line. The car doesn't run any more roughly than normal, it always starts - when the engine light comes on the car continues to run without a sputter. Last year the P0343 popped up 1 time - now the light comes on regularly. I have read posts regarding the 3 cam bolts becoming loose and I'm not discounting that, that may be my problem, but it's a lot of work to do the fix if it's possibly not the real issue. My impression is that it could possibly be a pinched wire or bad ground. Has anyone else run into this, or does anyone have a suggestion ?
Ken
Ken
