R
ReggieD
Intermitted Alternator or something ( 1992 vette)
Had problem earlier, I thought I fixed it.
New Battery (1 week old)
New Alternator. (1 week old)
Problem still here.
While driving the voltage meter in the car erratically jumps from 14.1 volt to 12.2 or lower.
Sometimes the alternator can handle full load (AC on, headlights on, etc.) with no problem and still supply car with 14.2 volts. On other occasions the alternator will be putting out 14.2 volts once I turn on something (AC, brake lights, head lights, or etc.) the voltage begins to jump around and drop back to a lower voltage around 12.2 or lower.
I have no idea what the problem could be.
Can it be another bad alternator? I want to check other components within the car which might cause the problem. Keep in mind the battery is one day newer than the alternator. I measured 78 amps drawing from the alternator with the AC on, headlights on, hood lights, and radio. During this test the alternator was still putting out 14.2 volts. Tomorrow I try to get the car to repeat the failure of the voltage dropping to around 12.2 voltages. At that time I will re-measure the current draw at the alternator. This might help me find what the problem may be.
I purchased my alternator from "The Last Detail" in Atlanta GA. it's a AC Delco rebuilt. I paid $144.00. Do I need to spend more money fro a better one?
Any ideas
Problem still here.
Any ideas
