forrest
Hi all just another one of those PITA problems, my dash has picked up a new trick, when first started the dash has a ghost like appearance the normal things show but behind and around them you can see things like Km and centigrade and all and all the unused icons then most of the time it just goes away after awhile only to return to go away rite now I am trying to check the grounds but they are a bit allusive and seem to be hiding well, as stated I am in the midst just starting to look for the problem or is there some one who can help me cut through the chase?
other than Grounds I wondering if it could be as stupid as a burnt bulb?
SOLUTION to problem after beating up my knuckles a bit I installed a beat up spare cluster I had, so the repair cluster needs replacement or repair.
