badnews
New member
Okay so the history is, its a 1996 Base Coupe LT1 Auto that has sat for 12 years it was having an issue the previous owner couldn't fix where it would idle fine and as soon as you put her in gear she would stall out so he parked her in his shop for a decade anyway. I bought her a couple of weeks ago and So far I installed a NewRockies VATS bypass module, I drained and mopped and scrubbed the tank clean, installed a new fuel pump and sock, changed the fluids and filters and most of the hoses, serpentine belt, new battery, put fresh gas and new fuel filter in and she cranked right up and started I let her run for 30 minuets burning all the cob webs and crude off and shut her down and restarted no less than 6 times during this process each time she started right up without even a full revolution of the crank. after the 30 minuets of running I shut her down and the heater hose looking hose the goes from the radiator tank to the inlet (which I had overlooked replacing) ruptured and shot all over the front of the motor including I am guessing the old Optispark. Went out the next morning and changed the ruptured hose and cranked her over and she didn't fire, she tried (burped a little) to but just didn't get to where she would catch, I went and bought a new Optispark unit thinking that might be the issue, along with new wires, (and discovered why there is a support group for those who have changed wires on an LT1, I am sure most of the skin on my knuckles will grow back eventually) new AC Delco Double platinum plugs, and installed them. Still nothing, I hooked up my Fuel pressure gauge to the Schrader valve still getting 44 psi on the rail, new fuel pump in singing for a couple of seconds when I power the key, even double checked the filter to make sure I am getting good flow through on the new filter just in case I had missed anything in the tank and it had clogged the new filter, I finally went to check the pulse on the injectors with my noid light and I don't appear to be getting any pulse to the injector,s in addition to that when I hook up the OBD2 reader I get Link Error and I tried both my little $100 hand held and my bigger OB2 reader both are getting a link error and here is the really crazy part now It wont start on starting fluid either it was before. I am getting Good solid Blue spark from the coil and out of the spark plug boot as well. I know that the injectors were working just fine the day before because it ran perfectly until that hose blew out. So I am wondering what to do next because I am about to send it in to the dealer to get a new PCM, BCM and a flash. the link error and no injector pulse is really making me think that the PCM is the issue especially after setting up that long in a shop by the beach. Any one have any other ideas what it could be? Any help would be appreciated.
