John Robinson
Gone but not forgotten
I have been chasing a number of SES issues lately and yesterday I discovered that the ground wire was broken inside the TPS plug. After repairing it I checked the TPS voltage and I have .7 at idle and 4.11at WOT. I seem to recall that the wot should be 10 times the value of the idle setting is that correct? Also I have read in the Chilton Manuel that it should be at least 5 volts at wot.(I also have the FSM but could not find corresponding information in it) The reference signal voltage is 5 volts.
Finally how Long will it take for the ECM to recognize the TPS values and adjust accordingly for performance and mileage.;help
