S
SwaveDave
Im going with an Electric Water Pump , for street. (Uh huhhh... thats right!)
I dont know how many miles are on my present mechanical water pump, so, i decided to replace it before i go on any long trips. I researched Electric ones, and am convinced it is the way to go. Meziere, CSI, and Moroso all advertise thier electric pumps for Drag and Street use. I talked to Don Meziere and his standard pumps rated at 35 gpm have a motor brush life of 10,000 hours and the seal life is 2500 hours. The Heavy Duty one, is 12,000 hours and 3000 hours. I drive my Vette April thru November and figure i drive roughly 100-125 hours per year max. So, it will last a long time. The advantages i have come up with are as follows:
1. An electric flows 35 gpm (standard duty) continuously. Thus, at idle when you need cooling the most, it is outflowing a mechanical pump., and should contribute to much better cooling. It is su fficient at higher street rpms such as 4000.
2. There is a H.P. gain from the engine not having to turn a pulley on a mechanical pump. (especially at higher rpms).
3. Having a dual electric radiator fan setup already, makes the ELectric Pump installation easy. The engine belt will only have to turn the alternator and p.s. pump with crankshaft. No modifications to the pulleys.
4. I already have an oversized alternator. The electric pump draws a meager 6 amps total.
5. They sure look good.
Im installing it this week, then shall do an analysis based on : Outside temp, water temp., rpms, and mph. Ill report my findings.
Dave
Dave
