6
69vettester
I want to run this past you guys and see what you think...
After getting what I think is the optimal airflow in and out of my motor a little starting problem has cropped up..heres what happens..
In the Morning cold motor 40 ambient or so , I choke her half way, she fires right up and I adjust the choke till she's warm, great. After the motors run, and I shut off, it appears that the combustion chambers load up with fuel(wet plugs)??Because then, when I try to restart the warmed motor I have to crank it for 3-4 seconds and then it will stumble to life just like a flooded motor does. Would the carb move to a too rich condition with these engine airflow and advance mods? 14degrees at idle,..Whats your thoughts on correcting this..should I be looking at leaning the holley out gradually?? The motor always fired right up before before the air and ignition upgrades..
Need anymore info, please ask...
Thanks in advance..
TC
PS No chance of a vacuum leak affecting this situation, I have it blocked at the manifold, so bypass that possibility
Thanks in advance..
TC
