A
AUSSIEVETTEMAN
OK, well I have done just about everything to reduce the temperatures on my old girl, but I am not winning.
We have:
Replaced the original 2" radiator for a big block/ HD radiator which has 4 rows and is 2 5/8" thick. This has been pressured tested and is OK.
Replaced the thermostat from a 195 degree to a 160 degree and this works fine.
Replaced the top and bottom radiator hoses with Coolflex hoses as these have a lifetime warranty and will not split or suck in while highway driving.
Replaced all of the seals around the radiator and shroud.
Replaced the 6 blade manual fan that was on the water pump with a 7 blade clutch fan, in hope that this will draw more air through the A/C cooler and radiator.
We have two new air dam extentions, thanks to Corvette Central, to put on the bottom of a new air dam they also supplied. (Ours was broken and the last owner bogged it up with body filler, but it has broken now). These have not yet been put on.
We have had the system pressure tested and this found a very small leak in the head gasket, but we replaced these when the new carb went on.
OK, here are the temps:
First start for the day will see the temp guage go up to around 180 before it dives back down to 160 indicating the thermostat is opening.
Normal driving and driving on the highway show temps of around 170 to 190 depending on what driving style!!
Driving in traffic is different though, she starts to pull temps of around 200 to 220 especially when in 'drive thru' resturants. If you put the A/C on, the auxillary fan will cool her slightly, but only a couple of degrees. As soon as you start driving again from being stuck in traffic, the temps go back down.
I think the air flow needs a bit of a 'touch up' and am thinking of a thermo fan that will suck a golf ball through a garden hose, well that type of power anyway.
What do you guys reckon or can you suggest anything I have missed???
Cheers
Tony
We have:
Cheers
Tony
