rmtsteve
I look @ a (2 owner with documentation)1988 automactic with 86000 miles today. It drove and shifted good and has new tires on it and a newer exhaust. The color is dark grey (charcoal?) exterior and light grey interior. The paint look good from about 10 feet but once you got close you could see it needed some attention in a few spots. The drivers seat was a power seat, but also needed to be recovered. The passenger seat was standard but look new. The A/C blew hot air and I was told that it had been recharge last year but is low again and could possibly have a slow leak. The dash lit up but the right side was a little dimmer then the left, can this be easly fix? The weather stripping didnt look perfect but all was intact and everything sill up good. It was raining when i test drove it and there were no leaks. The battery needed to be jump to get it started so when I was driving it I check out the volt reading and it was in the 13.2-13.7 range. Is this normal? All in all I thought that this could be a good daily driver that I could fix the little things (if these are little things) while I drive it and if I wanted to maybe later on invest in a partial or maybe even a whole paint job. The seller is asking 7900 but I was thinking of offering 6000-6500. Any and all thoughts would be appreceiated.
