74bigblock
'66 327/350 4-Speed
So we are knocking our heads trying to figure out if this TO Bearing is bad, or if it's just plain mis-shapen. Take a look at these two pix and let me know what you think. - On both pix, the old TO Bearing is on the left. We aren't sure if it is original, but the repro from LUK is totally different. Check it out...
You can see that the old TO Bearing is both larger (circumference) and taller by a few mm. Is this normal for a repro to be smaller?
Also, there is already a groove on the new TO bearing where it rides along the clutch. This TO bearing might have 300 miles on it. Again, is this normal?
The free play is not as bad as I was told, but basically the whole nylon housing portion moves about 2 mm from side to side, but not in and out. Normal?
Pix from camera phone:
