Subfixer
I have a 91 Isuzu Trooper, 2.8 TBI, 4X4, 5spd.
Two problems:
It will turn over and start but stalls in about 1 second.
It takes about 10 tries to get the truck to start. I have to keep my foot to the floor or it won't start.
Once it starts, I still have to keep my foot to the floor as it runs real rich (black exhaust) until the revs get up to 3-4K rpm. Then it clears up.
It does this every time I try to start it, warm or cold, even if I turn it off and immediately try to restart.
Problem 2:
Once it starts, it idles at around 2K rpm.
If I block the air feed to the IAC valve, I can get the idle down to around 850 rpm. I replaced the IAC valve, but there was no change. TPS is correctly set to 5.0 vdc (key on, engine off) also.
I've checked all the vacuum lines and sprayed WD40 around the base of the TBI without finding any problems. I checked the brake booster also.... no change.
Intake manifold gaskets were replaced last summer.
This problem started two nights ago after the truck sat for a month. Made the 60 mile trip home, high idle and all.
The check engine light does not come on and there are no codes stored in the ECM.
The high idle still sounds like it could be a vacuum leak, but I have yet to find it. Don't know if the hard starting is related, but I assume it is.
Help!!!.
			Two problems:
Problem 2:
Help!!!.
