8
89sleeper
To remove the wheels with the car on a 4post lift
I can't imagine how nervous you are with it up like that!!:ughThere is more movement of car on all 4 tires than on the jack stands (you have to remember the end with jack stands is solid and has no give)koolaid117 said:Good job!I can't imagine how nervous you are with it up like that!!:ugh
Jim
I jack the car up with the lift in the air I have a smaller floor jack a 1 1/2 tonNPI said:Stupid question - Are you jacking the car up while lift is lowered and putting the jackstands in the cross pan, or are you doing this with the car raised? I am considering a drive on lift which is why I am asking.
Sounds like it might workGrizzly said:I haven't tried it yet, but I have some big jackstands I use for lifted trucks, and I thought about placing them on the floor under the car and letting the lift down from under the car.
All four wheels off the ground near the ground for rotation or removal for a good scrubbing.!!!!!!!
stu said:Just wondering, where did you spot the jack stands in the rear? I've been placing mine by the jack points since they are the only place I know is solid.
