I bought 4 standard hockey pucks, drilled pilot holes in the center and screwed course thread, large eye hooks from HD in them to hold them in place in the frame jacking points. I purchased an American Forge and Foundry 2 Ton, low profile (2.75 ") $240.00 floor jack to jack up a side, then I use my old Sears 2 ton jack with a pice of 2X6 wolmanized lumber, cut 2' long and place it under the front frame section and then remove the low profile jack and install 8 ton jack stands on each side at the hockey puck points and then lower the car. Then I take the low profile jack with a pice of 2X6 across it and position it under the rear frame section, jack it up and place the jack stands on each end of the 2X6, I found that if I try to use the jack stands under the rear jacking points, the car is too high off the ground for my comfort level. Works well for me.
