S
Scottyboy
97 C5>>>>Just got through cleaning the MAF sensor and throttle body (Due to my Son over oiling the air filter).
Anyway, took care of that problem, but the same code is coming up. (P0102)will not erase >>( MAss or Vol. air flow circuit low Input)
She is back to running great, except now she is shifting REAL hard into gear from the parked position. She shifts out of every other gear just fine to me, even though my son said it was hard coming out of first as well???NOTE: I called my Vette Mechanic, and he said they will do that if idled too high? But if this is so, why did it just start after i simply cleaned the MAF&TB?
Could this have anything to do with me cleaning the mass air flow sensor or the TB? Or could it be due to the fact that the trans fluid needs changing?
I mean, to me seems like it would be due to me doing the cleaning, since i had no check engine light on untill then?And also, wouldn't it cause a problem in every gear if it had anyhting to do with the fluid needing to be changed?
ANybody know what i should do first?
Thanks!
Thanks!
