c4steve
Recently changed the fuel pump/strainer in my '89 and it was as easy as everyone say's
thanks to the handy info and friendly advice found here... Anyways after sitting for a day or so I did a pressure test on it a few minutes ago and with the key on it held an even 42psi and once started and idling it sat right around 38-39psi... Only thing is I dont know how old this pressure regulator is but are these readings pretty spot on? The car still cranks for a few seconds (cold and hot) but fires right to life,is that normal?
Do I or should I change the fuel pressure regulator for saftey precautions or get in and drive? I got new injectors/fpr but would rather not dig in to the car if I dont have to.
Any help would be appreciated!
