Just what is Opti Spark
samborskij
North Carolina
1994 White Coupe, 2004 Spiral Gray Coupe
Just what is Opti Spark and what does it do.? I see a lot of chatter about it and water. Not wet washing underhood, etc.
I'd ask you to make me smart but that may be too much to expect and too little knowledge can be dangerous. So make it just right! :confused Tnx, Sam
The Optispark replaces the standard distributor. It actually works better than a std distributor, significantly increasing power through accurate timing, while improving cold and hot starts.
The device, unfortunately, sits just below and behind the water pump. It sits there so it can be directly driven from the cam.
Hope this helps.
